I am in the middle of installing HAL shocks, Hotchkis springs, Xtend LCA's and sway bar. everything is on but when I put on the rear sway bar it looks like it is hanging really low. The car is still up on the lift but it is almost 2 1/2 inches lower than the rear differential. Does anyone have any pics of it installed so i can make sure i have it on correctly. Thanks
A
Sounds correct, it looks a lot lower when it is on the lift (and thus the back of the lower arms are pointed down) than it will be when the car is on the ground.
Thanks AutocroSSer. By any chance would you happen to have any pictures of the rear suspension showing the sway bar??? I just wanna make sure this thing is on right. Thanks again for your assistance.
Thanks Tom, I guess I have it on the correct way. It just looked funny hanging so low. This is all the stuff that I got from you back in 2002. I am finally getting around to putting it on the ride after my long vacation in the Desert. Thanks again.
