Apparently I somehow missed about a hundred posts stating not to reuse the bolts for the front sway bar mounts :( I cleaned the originals up and greased them well, some of the threads looked a little worn, but decided to reinstall them anyway. Seemed like they went in fine, and tightened up pretty dang tight without any fuss. Still seem to be holding tight 2 weeks later after a good bit of spirited driving.
So what do I do? Leave them in, check them often, and keep my fingers crossed? Or take them out, hoping it doesn't strip the frame, and put new ones in while holding my breath?
I did just as you did----2 years ago. Mine are still tight and holding good-------could i be the exception to the rule? I don't know, but I do know they are still holding.
ive replaced swaybar bushings many times without stripping frame. Has happened only once so i used a nut and bolt on that one through a frame hole.
Leave it alone LOL
What Shane said. I installed my F-Body bar in '97 with the original bolts anad they are still tight and all there. Those taht know me know I do have a tendency to drive in a "spirited manner". :rolleyes:
SStewart
