·Added 5/18: first 15 sold out!!
I broke the retaining clip on the Opti plug the other day. If any of you have looked at it, the connector is a "pull to seat" style connector meaning that the wire is run into the connector, then the terminal is crimped on. If you break the connector, you need to cut the wires if you want to replace just the connector.
I got sticker shock when I went and priced out a new Opti harness. $130 list, Dal/GMpartsdirect price is in the $90 range!!!!
So I did some digging, found all the parts to make the harness myself, and figured others would want them too. My harnesses will be the same length and use the same connectors as the factory harness. The only difference will be that I will use all black or all white wire in order to keep costs down. You can still trace the leads since the circuits listed in the FSM show wire color and cavity number (connector is labelled as well) in the connector end views.
Wire used will be TXL or GXL wire. TXL is the OEM wire, GXL has the same properties, but with thicker insulation.
How many would be interested in these for $33 shipped?
