www.rockauto.com should, or your favorite parts store. Steering box--there are lots of threads about better replacement boxes.
Technically, yes.Are all the steering boxes interchangeable?
No. The police (9C1) boxes have a different spline for the pitman arm. It is worth checking the spline count before ordering as someone could have swapped in a 9C1 box.. This just happened to someone.Are all the steering boxes interchangeable?
Since circumstances have forced you to settle,210309[/ATTACH]
Here are the ones I am looking at rebuilt.
what do I go with? my car is in the shop now so I have to get one asap
If time were on your side this would be the far better option.Keep your steering box to be rebuilt.
Even if you are not having yours rebuilt, you should know yours well enough that when you buy the RockAuto one, you're immediately sure about whether or not the new steering gearbox is 'the one'.... have the one from the car checked for correct specifications (no tire rub with stock tires etc), then have it rebuilt.
Again,A N40 code is power steering and is on all cars.
