1 - 20 of 35 Posts
Hi everyone, weird issue. My parking lights don't seem to be working when I turn them on. The same lights work when the hazards are on / signaling to turn. Not sure why the parking lights themselves are not working. Blubs look good, should/which blubs should I replace?
Hazard/signal lights are a different circuit. I would look at the switch.
  • Like
Reactions: Z09B4U
IE: check fuses, check that the wires are supplying power to and from the switch.
Automotive tire Bicycle part Motor vehicle Electronic engineering Electronic component
IF, I repeat IF you find a blown fuse you MAY(no guarantee) have a bad bulb. look for one that is damaged.
Again IF the fuse is blown you could take out all the bulbs and see if the fuse does not blow.
Liquid Drinkware Fluid Cork Glass bottle
you have one for sale? Or can point me to the correct replacement?
Font Art Machine Illustration Auto part
Definitely check fuse first. The park lamps not only use a different circuit but also a different filament in each of the larger bulbs. So it's possible for the TS and hazards to work fine and not the park lamps just due to a blown fuse.
To check the fuse, a video speaks 1000 words.
Let's get some details clarified here because I can't read minds nor do I have your car:
"Noise" as in the "ding ding ding"? (note: this only dings with the key off)
"Noise" in your context could also mean the switch clicks. Just making sure.
Is the switch only in first click -- "P" position?
Are the dash lights on?
And NONE of the outside lamps are on?
OK, sounds good. I've never heard of these switches failing this way. But I guess it's possible. That's why I wanted to eliminate other variables (ie: starting with the fuse).
Before you replace the switch, the final variable is what options are installed on the car?
Do you have twilight sentinel?
Do you have an alarm system or remote start?
Do you have a trailer hitch with a wiring harness?
Anything like that which would be plumbed into the parking lamps.
I guess switch is next up to replace.
Yes you are just guessing.
I have the twilight sentinel
The diagrams in the 94 FSM seem to show that the twilight sentinel can turn on the park lamps independently of the head light switch. (the switch and relay are in parallel)
So if the headlight switch AND the twilight sentinel do not turn on the park lights there is a VERY low probability replacing the headlight switch and twilight sentinel controls will help.
People are taking the time to try and help you and you do not seem to care enough to answer simple but important questions.
If you do not have park lights(front and rear separately fused), no dash lights, and no cornering lights:
There are two high probability solutions. You have a blown ext LPS fuse or a bad wire or connection. This is easily tested.
What is a low probability is both the park switch and the twilight sentinel controls have both failed at the same time.
If all the lights have failed(dash, cornering and park) AND twilight sentinel and headlight switch do not work it may be a wiring fault or fuse.
Discussion Starter · #14 ·
Sorry @Z09B4U but, I think I described the issue I am encountering at the beginning, never did I mention anything about dash lights being out or tail lights. I have checked all my fuses. While I am very appreciative for all the assistance, for you to make the assumption I am not taking the advice from other is not accurate.
This is why we come here for help. If you perform a search of this similar issue, you do not find much if any who posted the similar issue and followed up with an actual resolution.
Thread title:
Parking lights not working
The headlight switch and the twilight sentinel control the park light circuits. GM describes the three circuits as int dim(instrument), fwd lps, and rr t lps(AKA "tail lamps")
By GM definition and common conciseness park and "tail lights" describe the same thing.
Yet you have been asked twice now.
Crickets....
Discussion Starter · #20 ·
Hey guys, I have a ground issue. I confirmed this by using my test light touched bare metal and the test light lit up. I also noticed on the fuseblock some of the fuses lit up the opposite way meaning the test l
1 - 20 of 35 Posts
