21 - 31 of 31 Posts
Depends on what circuit you were testing. If it's hot all the time, you're going to get a signal all the time, not just when the car's on.
Discussion Starter · #23 · (Edited)
Morning all, I'm still trying to fix my issue where my parking lights (amber) don't come on. They will only flash when the headlights are on and I need to signal to change lanes. But they do not turn on when I simply want to drive with my parking lights on or on when I have the headlights on.
The dash lights are not working either. I have replaced the dimmer module under the driver-side dash, but that didn't fix the issue. I have tested fuses, and nothing is blown, and as far as I recall I have not made any changes that involved electrical. I have looked through other posts, and none seem to be similar to my issue, and it's been resolved.
Id likes to drive my imp at night without having to turn on the dome light to see my gauges.
This is probably a ground issue.
Ground fault, not an incorrect ground.
Check out Henry '06's last thread about this same issue.
Discussion Starter · #31 ·
Where should I start, in regard to troubleshooting? Changed builds, parking, and corner, happy to check those again. Replaced the dimmer module under the dash, no luck with either.
21 - 31 of 31 Posts
