D
Anyone know the part # for the front sway bar (the second gen. f body one) ? I tried the one in the tech tip, but it doesn't seem to show up... Has it changed?
N
The GM number was 436954, I think. No longer available, supposedly.
Here you go: From NPD, part #c-7241-02a, Phone # 1-800-235-3445. About $122.00 delivered. Includes brackets, endlinks, poly bushings. Everything you need except new bracket BOLTS. Bolts are from GM, part#15959689, you need four. And no I don't work for NPD or GM. Just try'n to help! :D Scott D.
D
Any opinions on which front bar is better, the f body or the HO/HA? I'm not a racer by any means, so I'm not sure what setup is best for me...
I think BMR has a nice alternative to the NPD bar. BMR wants a little more money. The NPD bar is anodized gold color whereas the BMR is red. Both are good...your decision. ;) Scott D.
If you want neutral handling, get the 2nd Gen. F-body front bar and H-O rear bar. This is a great combination.
Scott D.
Correction: You have a choice of colors with the BMR front bar.
:D Scott D.
