81 - 100 of 100 Posts
No!!! All PM's weren't replied to....Never mind, and I was patient too...
Discussion Starter #84
Heads are Sold. I just sent Lloyd an email on them.
The rear seats are no longer for sale. A stray dog came into the garage and ate the lower seat.
if not sold , are the pushrods stock 7.120 length ?
Price for the upper backrest skin ?
Hopefully you got some parts left. I PM'd you. Sucks to here your son crashed the Imp,Sorry
My son totaled my 96 Impala and I have demodded and have the following parts for sale.
Hotchkis rear sway bar (updated thicker bolt area) $175
F-body front sway bar with energy suspension bushings $40
BMR Lower tubular lower rear control arms $155
TrickFlow pushrods used (2 of 16) less than 1 month $50
Set of 4 wheels decoated with ContiExtreme Contact 275/40/17 $350
Autometer Oil pressure gauge and 6 Ft steel braid hose $55
Metal Pedal Covers $50
Seatcover passenger and foam upper/lower $125
Head Rest $30
Idler Pulley less than 1 month old $25
IRS Red MAF ends Ported no bars some scratches $30
Stock ported descreened MAF $30
Speedometer Cluster with resistor fix for odometer $90
AC Compressor, 1 year old Plus Lines $60
Altenator $30
Earl’sSteel brake lines $60
All items minus shipping
Eaton Posi used/3.42 ring pinion SOLD
ODB I conversion PCM for a 96, programmed by Bryan Herter. SOLD
ODB II PCM $60 (Used just for emissions) SOLD
ODB Cable from AKM electronics. Pinned for ODB I commms with ODB II port. SOLD
MSD6AL purchased with harness to switch back to factory ignition and accell coil. SOLD
Random Tech cats (gutted) SOLD
Edge Street Edge 3100 Stall approximately 15,000 since refresh and no ¼ runs SOLD
Level 3 Carolina Performance Tranny 15,000 miles with shift kit (2 washers) SOLD
Clear Image driveshaft safety loop SOLD
30 Lb SVO injectors SOLD
52mm Throttle body Ported by David Koldos SOLD
Harmonic Balancer less than 1 month old Sold
Ported black powder coated intake (ported and gasket matched for Lloyd Elliot heads $200 SOLD
Spintech Mufflers Local pickup they are welded to exhaust SOLD
SSRI Intake and Filter fromclear image old and some cracks still works
great comes with filter SOLD
Gen I Tri-Y headers from Clear Image Gun metal colored coating, a few spots, Header bolts need replaced. SOLD
Comp Magnum 1.6 Roller Rocker many miles still great SOLD
Water Pump less than 1 month old SOLD
Lloyd Elliott Stage 2 heads sitting in Lloyds shop. They got new valve guides, resurfaced and ported. I did not put in valves or springs as you may want something custom and You can have Lloyd complete. I am asking SOLD.
PM for details or contact me at my work address [email protected]
404-720-4124
This is an 11 year old post from a member that hasn't been to the site in a decade, stop asking if he still has parts, lol.
..........PM for details or contact me at my work address [email protected]
404-720-4124
Hey.....is that ceramic flux capacitor still available? And is it a 2-wire or a 3-wire.....I really need the 3-wire. :confused:
KW
