PASS KEY FAULT Light on Continuous - Car Starts
I've read through most of the posts in this 20 page sticky. I appear to now have the "fail-enable mode" active on my 96 Caprice because the Pass Key Fault light is now on continuously and the car has started 5 times.
I cleaned the key and the chip with rubbing alcohol. No change. I read that you should also try to clean the ignition cylinder. I have not read any description of how to swab it out. I'm guessing that if I try a Q-tip, the cotton head will stay inside the cylinder and I would be really screwed.
I'm confused on the reset procedure. The amount of time to leave the key in the "ON" position ranges from 1 minute to 11 minutes and then turning the key off and waiting 5 seconds to 30 seconds before trying to start the car.
I forget the exact security system but this car has what I think is the GM VSS-150 system. Could some part of this system failing cause this light to come on?
Also after reading the 20 pages of posts, I either missed a diagram of the system or no one posted any so that I could locate the anti-theft module and the anti-theft relay. Where are they and what do they look like? In an F-body related discussion of the VATS, one of these items (module or relay - I forget which) is under the dash on the passenger side of the car. Is it in the same general location for B-bodies?
Since my car starts with a solid, steady light, I'm thinking that I need to do something other than the resister bypass for the key to turn the light off.
Any help is appreciated.
