Is the spot light the universal for both sides or they just one fliped up side down?
the moutning bracket is different
I would imagine the actual spotlight is the same. (perhaps they had the toggle switch operating oposite but who knows)
D
I have a set of the OEM lights, L & R. I'm in the process of mounting the pass. side light, my car didn't have one originally. I can see no difference between the spotlights. Even the switches turn the same way. And as mentioned above, the mounting brackets are different.
James
Since your cuting im planing on puting a set on a roadmaster to make it look like a 50`s hot rod look. How are you going about drilling and cutting the car? what size is the hole that goes through the pilar? So what your saying is that all I need to do is find the passanger side bracket and ill be set?
