The front passenger side tire has excessive wear around the outter edge. What could cause this? Im thinking idler arm.
Could be any of a myriad of front end parts, as well as just a bad alignment.
Start checking the parts first....if all check out OK, then go get it aligned by a good place (hint : the $40 "lifetime alignment" place is pretty unlikely to do a good job ;) ).
Well I swapped the wheels from one side to the other and now the car pulls the other way. That kinda narrows things down a bit
I was having the same problem. Tire wear on the ouside of the P-side front tire, but mine was an alignment issue: P-side tire was way out of alignment.
