T
I searched but I couldn't find the instructions. If anyone could help me I would really appreciate it.
How does one remove their pcm? Are there any instructions online? I found F-Body instructions but was wondering about B-body specific ones. I went to send it out to PCM For Less for reprogramming.
Just remove the air filter box, then the pcm is held in a black plastic case that undoes by two clips on the back (towards the firewall) and the pcm will lift out. Remove the 4 wireing harness and your should be good to go.
N
Make sure you disconect you battery before
unpluging the PCM from the connectors !
I (and many others) have swapped PCM's without dissconnecting the battery. No problems at all.
Anthony, you saw me pull Ramsey's PCM when we were doing your headers. We pulled it out that same day to do his B&M shift improver kit...
