i bought a pcv valve for my 96 ss. is it located on the pass. side valve cover? I just bought the car and changed the oil and purchased a pcv valve for the car. When i removed the hose that goes to the valve cover nothing was there. Im stumped. do i just place the fat end of the pcv valve in the hole and connect the hose to the top of it.
also does the pcv valve on the lt1's have a rubber grommet?
The PCV valve is on the drivers side of the intake manifold. The hose for it goes from the front of the intake manifold through a 90 degree curved rubber hose to a metal pipe, to another rubber hose to the intake manifold. The hose you are referring to is the blowby gas/engine breather hose that runs from the passenger side intake manifold to the throttle body and has nothing to do with the PCV system. - Peter
thank you for getting me straight. I dont know what I would have done without this forum. thanks. Its my first gas vehicle. LOL
Actually, it's an integral component of the PCV system. People have played w/ this one for years. Blowby introduced into the intake vs. unmetered air and invalid MAP readings.
Keep all vacuum fittings intact and/or upgraded. This includes the entire PCV circuit (both driver's and passenger side).
What DOES reduce passenger side PCV circuit oil/blowby is a chambered design breather which prevents oil from readily being introduced to the intake manifold and this:
GM part# 12572717
What the pic doesn't show is the "fixed orifice" design of this valve. Been using it recently, and it does just what it's supposed to do.
