Had to really get on the brakes for the first time ever today. Pedal went to the floor but was still stopping pretty well. Tires were chirping a little bit but no wheel lock-up. Is this a normal thing or do I need to investigate my brake system? BTW 95 9c1. Thanks, NAES
Your pedal should not go to the floor. If you braked hard enough your tires will chirp a little since the ABS is working. They should not lock up. Sounds like you may have some air in the lines. Bleed your brakes. I would change your fluid if you have not done so in the last two years.
