·I hit the zircs with grease and while I did that, the pitman arm moved DOWN about 1/8".
I do have a little side/side slop in the wheel. Do you guys think I could get side/side slop from a pitman arm that moves up/down only? [I have recently replaced some BJs and bushings - I think there is no other component that could cause the slop except for the steering box]
Any of you other guys see movement in the pitman arm while greasing? Do you also see slop?
