thats too wide of a question, the one on my impala has ogne 50k miles i have replaced 5 on my caprice.i feel like my car is just slow is hell it has a fresh set of wires & plugs and i have had the car for bout 11 months and i think that is might be tyme for 1 how long do they last.
CEL = check engine lightit has about 170,xxx what is a maf again sorry stupid question and naw it not really runny smooth i had to reakky put my foot in her to make her move and naw i havent replace any of them things my check eng light on but it says it my o2s and what a CEL?
So, your CEL is on for O2's, but you're looking at other items?! Start with what you KNOW is broken. What's the specific code # its throwing?im lookin into them thing to day cel is on beccause my 02 sensors and im gonna check the egr thanx
He speaks the truth, if you got an existing condition thats bad enough to throw a code, id start with it before throwing costly parts at it. Are you getting a primary o2 code or a secondary o2 code? I know they arent cheap if you buy the AC o2's (dont cheap out and buy bosch!), but if its a primary o2 code, the car is gonna run like crap (thats a little harsh, maybe "less than optimal). Btw, to clean the MAF, remove it from the car, remove the screen, and CAREFULLY take a cotton swab with rubbing alcohol and clean up the tiny resistor wires inside the MAF housing. Be easy, they are fragile, and once broke the MAF is rendered useless. Cleaning the TB requires just a can of TB cleaner, or carb. cleaner. Take the rubber intake elbow off, and spray the gunk off the throttle blades. Also spray around the bore openings to ensure the throttle blades arent sticking.So, your CEL is on for O2's, but you're looking at other items?! Start with what you KNOW is broken. What's the specific code # its throwing?
1. P0100 OBD-II Trouble Codethanx i got the code for it now
1. po100 mass airflow
o2'sthanx i got the code for it now
2. po141002 Bank 1 sensor 2
3. p1415 air system
thanx for the help so far and right about now i took apart the maf cleaned it out and put it back in i could tell its a lil better after that and next im doin the egr valve and the coil i just put my order in with my supplier and then this weekend ima take off the throttle bodie and clean all the gunk off it and in it.
a maf from another impala/9c1/caprice that works has no issues.stupid question but what is a KNOWN workin maff
P0100 - MAF again. You've got a MAF problem. Check wiring. If not wiring, replace MAF. Fix this code BEFORE worrying about the others.back agin yall i got 3 new codes
p0100
p1415
p1441
