1 - 20 of 26 Posts
F
i am sure we all want to see everyone's trunks
if you got fresh pics post em
if you need fresh pics take em
i can't start with mine, because i ripped it all out again , and re-did it again , it is done as of 10/29/06 , but need to take photo
will post mine tommorow
someone kick it off
F
1st shot
removed driver side amp board
removed grey vinyl
removed 2 punch mono amps 1400 watts
carpeted panel
installed power 2000 2850 watts @ 1 ohm
i installed amp upside down to access controls
so i would not have to break system down for
adjustments or maintenance
2nd shot
removed passenger side amp board
removed grey vinyl
removed punch 800 4 channel 200 watts x 4
removed crossovers
carpeted panel
installed crossovers
installed TYPE RF X2 Amp
this amp is adjusted thru LCD display
so i mounted upside down for easy adjustment
and or future maintenance with out any dis-assembly
when going from 3 amps to 2 amps this leaves me needing to swap my 1 in 3 out distribution blocks
ordered parts not in yet
when they come
will make new board for the new distribution blocks , carpet , install, and of course delete the extra none used holes in board that were for the 3rd amp
peace
H
still gotta wrap the box but here goes the wagon
I have a jbl gto 600.1under the floor
P
Just posted up in the other thread, but here goes again:
no trunk rattle, no noises, plenty of bass.
three 8" JL Audio W7
Memphis ST1000D
Memphis ST3004
2 optima yellow tops
thats it in the trunk (for now). TVs and mids are all up front.
Damnn pimp that is sick. As far as your sub set up that is how I plan on doing mine. I am trying to get 2 Memphis M312's in there but might have to go with 10's. Again man very sick.
L
DAaaaaaaamn Pimp. I like that shyt. Might have to do that over here in car jacking ass DC
U
Here's a really old one with 2 12" magnums...
This was absolutely ridiculous...
HEre was the sealed box for the Q's.
Not a trunk shot, but here's what happened to the sedan last.
UCP how many cubes was the box for the mags gross, and then just after displacement.
U
Discussion Starter #15
7.3 and 5 70ish for the port and tuned to 28.
I wish I would have sold mass copies of that box, it was perfect for 2 12's in a b body.
Originally posted by imposster96:
[IMG
http://i79.photobucket.com/albums/j150/IMPALA95SS_2006/IMG_0162.jpg[/IMG]
What do you guys think?
I dont like the way it sound what do you guys think i sould do to change it?
My only reccomendations.... build a new box.
My boxes may not be pretty, but they sound good.
I'd bet if you tore out that install, and put in a box just like that 2 12" one I have shown above you'd love the way it sounded.
You'd probably also hate to look at it, but sacrifices must be made!
:D
I
Discussion Starter #16
they are not 12 they are the 13.5, it hits but i dont feal it in the car. so i wanted to change it
U
Discussion Starter #17
OK, so put it in a slightly larger version? jeez...
The main problem I see is that your installer seemed more concerned with making it look good than making is sound good. Looks to me that he blocked off most of the airflow into the cabin.
Not a very good install IMO. It looks great, don't get me wrong, but if you have 2 bad ass subs and is doesn't get loud then somethings wrong with the install.
My point is, although a box like the one in my post doesn't look all that great it does what it needs to very well.
U
Discussion Starter #19
I would just try opening the trunk into the cabin. You could cut holes into your beauty board and cover them with grille cloth, that would help you keep the same look, but get more sound into the cabin.
[ 11-26-2006, 01:11 PM: Message edited by: UndercoverPunk ]
1 - 20 of 26 Posts
