Go to the junk yard and grab a caprice fixed antenna. Easy to wire, cheap and you never have to worry about it breaking off. The eBay antenna is "power" but not retractable. Not worth the money IMO. The junk yard one will look better and correct for the car.
The cable is still available at http://www.antennamastsrus.com/GM/Cheverolet/Caprice/Caprice 1991-1996.htm.
The only place you will find a "new" mast is on a wagon or Caprice/Impala. I think I have found another small source on 86 and 87 Eldorados. The base of the Eldos antennas is not compatible, but the mast is a 4 segment unit like the Caprice mast. If you want a repaired antenna with a good mast, I can help you. PM me.
