Hey guys,
When I bought my RMS, the stock power antenna would not go up all the way or rather it would fall down to half it's length. I went to the junk yard and found a replacement antenna, but it was from a Lincoln town car. The antenna looked to be the same and it matched up perfectly to the hole in the rear fender. I removed the electrical square connector thing that was attached to to the original antenna (held on by one screw) and attached it to the new one. Well, The reception is horrible with the junk yard antenna. The antenna goes up and down just like it should. I made sure the lead power is connected securely to the antenna, but that doesn't seem to help at all; the radio will not find a sigle station when I press the seek/scan button or turn manually..... what gives?
Thanks!
The coaxial cable may not be making contact with the antenna. That is how the radio gets the signal. If there is no signal on the coaxial center lead, you will not get any radio.
Ah, maybe there is a difference in the "depth" of the antenna connection on the coaxial cable as you mentioned; not making a good contact.
