·96 SS, leaking azz power steering pump. Ok, I get the unit out pretty fast, quicker then expected, maybe 30 min. I did not have to remove any rad hoses either. Just unbolted the little bracket from alt that holds the two heater core hoses. Took Alt off, then pulled up the PS unit out a little so the back pressure line was easy to remove then just worked her thru the heater hoses, not a problem there at all.
The line looks good, the black O-ring on the pump end of line looked a little ate up but before I took unit off I did look at the back end of pump, none of the lines into it seems to be the issue, pretty dry nothing to say it was soaking that area at the least. Is there a seal in front of pump at pulley?
I don't think I need to replace the line, can I just get the two O-rings on the line, at pump and at box? And what is that switch for that is part of the line??
Anyone having PS unit issues and want to replace it yourself, this job is pretty easy. If I can do it, anyone can with time and the right tools. Just unbolt the bracket holding the PS unit, 4 bolts I think, one is sorta hidden at the bottom right, move unit a little frwrd, remove lines, then slide it out.
