So I've got a leak coming from the back of the power steering pump and I'm trying to get to the pressure hose on the back because I'm thinking I just need to replace the O-ring on the end of the line where it goes into the pump. My question is kind of two parts 1) What's the best method of taking the pulley off the pump to get to the bolts holding the pump on the bracket? I have the pulley puller but not sure if I need to break out the hand ratchet or if there's a way to get an electric impact wrench in there to make my life a little easier? (I could use a really good reason to buy myself an electric impact wrench, but I want to make sure I get one that will fit and still pull the pulley off) 2) Where can I find and o-ring to fit the pressure line, or what size is the o-ring itself?
I also considered just taking the whole bracket off with the power steering pump still attached and THEN pulling the pulley off. That would give me more room to work on the high pressure line, but I'm just not sure how feasible that is. Any advice is welcome and appreciated!
