My driver power window has statred to make a clicking noise and gets stuck when I roll it up or down. I took the door panel off to see whats what and that was no help. The motor then would only click but not move the window. How do you even get the motor out to replace it? I have not done a search yet because I am headed to work and do not have much time I just wanted to post something try to find out what I need. Thanks
It should be easy to find the instructions with the search function. You need a 1/4 inch drill, bolts and nyloc nuts to replace the rivets, a screwdriver or pry bar to disconnect the ball studs, 10mm socket to remove the lower track, and depending on whether you replace just the motor, or the whole regulator, various other drills, and wrenches.
Use new tree fasteners when reassembling the door panel for a good tight fit, and while you are in the door, replace any OEM sliders with rollers.
