Hello all. I'm in the process of installing a new powersteering pump, both powersteering lines and "DIY rebuilding my steering gear. My system will be pretty much very cleaned out and new fluid running through it. After all this work, I'm debating splicing in a powersteering filter. I'd like the filter to 1. Keep my system clean as the BBB pump warranty kind of requires a filter be installed, a flushed system ( mine will be all new so ✅). 2. I'm thinking if a filter is spliced in at a location on the factory routing somewhere on the crossmember if possible?,, I will be able to disconnect the line there and pump all the old fluid out easier vs the difficult factory way of draining above the AC compressor. This is my thinking of how it was/is and a now thought up basic way of how I can make it run clean and easily flushable for the future. Would I benefit from splicing in a powersteering filter on a new Gates hose and system? Or would this be considered hacking a brand new nice hose for not much benefits and an overrated mod? IDK. How many years does a filter add to a brand new system? Would I just be adding extra work of changing filters that don't need changed, adding new fluid for exchange of just a few years more on a 25 year potential lifespan of my system? I've seen the Oil cooler mod and Trans mod to Aluminum AN fittings. I'm liking that mod job done correctly to eliminate leaks. I'm looking for where I can possibly add fittings on both sides of a filter without traditional clamps. Something really sealed and wrench tightenable.I don't want to add a cooler pulling lines onto the radiator support as I don't beat my car that bad while living in the desert. Can nice fittings and an adaptable filter fit within its factory routing providing a drain/flush point? Here is a my lines before removing my them. I'm wondering if some type of wrenchable fittings onto filter will fit in my yellow boxed areas. Has anyone done this? I don't like the idea of cutting a new hose if it's not going to really do anything. Are these filters worth it? I'm guessing mine worked fine without filter and still was going for 25 years. But then if it's going to Last 35 years with filters that's something to consider.. Thanks
