i just put on a disc convertion kit on my 96 caprice which came with drum brakes in the rear.. do i need to change the proportioning valve? will the rear brakes have enough preasure to work properly.. and where do i look for a direct bolt on, if such a thing, proportioning valve.. thanks..
The 9C1 and SS which came with discs came with the same proportioning valve as the drum cars did, they worked like that just not as well as they could have. What you need to do is the "stealth bolt mod" there should be more info in the "cheap" link in my sig.
