I plan on getting Impala wheels and BFGs or RE730s. What is the tire pressure that is listed on teh drivers door? Thanks
I have the RE730's and I'm running between 36-40 psi. The seem to be wearing fine so far (8k miles on them so far).
The door sticker says to run 30 psi. The original Comp T/A's wore out real quickly and I put 2 more on the front. I currently run 40 psi in them and they seem to be holding up better. I see the sidewall on them says that they can go to 44 psi.
My teeth chatter above 35PSI (too much raod noise/vibration) on the street, I like about 10% over the factory rec of 30lbs, so I run 33-34..... :D :cool:
I roll on 35 PSI....seems to have the best balance of handling, wear, etc.
KW
