·I have the button mounted,but trying to figure out the color code and how to wire up the relay. Could anyone tell me how to wire this up. I know the yellow,pink,And red wires are for the starter right??
There is NO real color code with a relay, assuming you got a pre-wired relay harness. The key for wiring a relay is how you wire 85 and 86(the coil wires) and 87 and 87a(the switch wires). You'll want to hook your starter button to either 85 or 86, with the left over going to power or ground, according to your plan. Then, when you press the button it trips the switch to connect the two 87's or 87 and 87a, whichever you chose or however you've planned. Also, make sure your relay is big enough. Don't put in a 30 amp where a 40 amp is needed and with that much power it might be a good idea to use a diode.Originally posted by sik96ss:
Reading the relay info,and the color code description is going to help thanks guys
