So I have a 1995 Buick Roadmaster with an aftermarket radio. So we all know about the gray wire and the purple wire. And the issue with dimming the vacuum fluorescent display on the A/C control unit. I did the typical solution of wiring a circuit board from an old radio. looks like this:
http://chillrobb.com/roadmaster/F/PWM2.jpg
I tried something different by wiring this:
http://chillrobb.com/roadmaster/F/sm_MODULE.jpg
I wired this thing up and it worked great, with one exception. The result was something like the opposite of what I wanted. I was excited because it worked at all, the problem was that when I adjusted to low dim the display got brighter, and when I turned the knob for high brightness, the A/C display got dim.
Any input?
was going to get back to you on the other message board bout this. links aint working.
So did you come up with any alternate solutions?
I ordered a different DC to PWM circuit board that I am going to try out. I was even thinking of buying this thing labeled as LED dimming controller, but that's $30, and I fear the same results as last time. I'm not really sure what's going on with the module I tried. Like I said it works in the opposite manner, but it actually works better than the factory radio. The range of brightness was much greater.
i gave up after searching ebay and amazon for a pwm convertor and couldnt pick one. i was on youtube and saw one that was a dimmer control and i was going to get it but i couldnt get the guy to respond back to find out which one it was. if you could put the pics up on another hosting site i think they will work.
I don't know why it's not working for you, works for me on multiple devices. Lately it has seemed to be a crappy host, I'll agree.
Try looking at these:
https://goo.gl/photos/kWVtt9niS8TxvcnPA
The first pic is the module I used and the other three are someone elses pictures, but the same idea of using the factory board.
check this out too: http://www.amazon.com/dp/B00PQASDX0?psc=1
This was something I was thinking of trying, but I think it's too expensive just to try, but maybe worth it if it works.
