Was wondering if any guys out there had any issues out there with the fitment of these headers?Wanna make sure that these fit without any problems..
Pics would be greatI just put an older set on the TurboWagon and had minor issues with the A-arm frame braces. On the drivers side I was able to roll the lower edge of the brace up and touch it up with a BFH. On the PAX side it's probably not an issue since when the motor torques over it's away from the brace, but I ground an extra 1/4" on the upper lip to have a full 1/2" of clearance. I can try to take some pictures this evening and post.
Here's a couple of shots of each side. I tried to highlight the areas and put in a dialog box, but they may be too small to see/read. The real problem was on the drivers side in that the tube was almost touching , and once the motor torqued at all would surely hit. I have a good 1/2" of clearance once I bent the edge of the brace over.Pics would be great
