1 - 20 of 26 Posts
I finally got the T56 in and the 4.10 rear gear installed and I am beyond thrilled. I have however noticed an odd thing and I am wondering if its just me or if this is common. When I am , for example, just cruzing on the freeway. If I have the ac on I can actully feel a subtle jerk in the car when the AC clutch kicks on. Is this just something normal for this setup or is it a sign that parhaps my ac unit is providing a higher than normal load when it is engaged?
On a side note... Everyone should have a T56 and 4.10s in their cars. It is awesome!
I have a T-56 and 4:10s also. Mine doe'snt do what your describing. What clutch and flywheel do you have? I have a stock LT1 camaro flywheel and a centerforce stage 3 clutch and plate.
And your right its awesome.Once you get its like getting a new car!
Stock camaro clutch and flywheel. It is real odd. I have owned several manual cars and never noticed this before. I wonder if maybe its my ac compressor, but there are no odd noises from it and it still works just fine so I'm a little perplexed
Have had T56/4:10 since 05 with several types of clutchs and now a McLeod "non sprung hub" twin. No feeling of AC clutch kicking in as OP describes
The only problem I continue to have is my rear tires wear faster than the fronts...
yeah, GM should have offered the SS with a T56 :)
Never had that issue either. I do have issues with the PS pump nearly stalling it although that's getting better the more I tune.
You're running the 5 spring hub right? Not the one with 4. I went through the ones with 4 a few times before I found a 5 at my local Autozone.
-Brian
Yess!
Just purchased my T56 lookin to start the install in a month or so. Also gonna be installingy new built 9c1 rear end with 410s I'm excited!
I've had my T56 and 4.56's in since 2004 and haven't noticed the compressor switching on/off. I used to run a Spec 4 unsprung but now run a spec 4+ unsprung if that helps at all.
Discussion Starter · #9 ·
I guess it's just my car being a moody pain. According to the gf I gave the car a sex change because now it has a stick to play with but I am guessing it still has the hormones it had before the surgery. At least at the moment it isn't a huge thing, just a little annoying as I always want everything to work just right. Not always an option with 210,000 miles on the clock.
What did you do with the Park Neutral wiring?
What flash is in the PCM ?
At the moment it is connected to the park switch from the colum shifter. The car will start any time I turn the key no matter what I do. I plan to wire it to the clutch next time I dig in to the wiring. I have the computer flashed by Brian H at PCM For Less for the manual. I did get the z28 cluster installed last night though so at least I have a tach. I should have wired the reverse lockout and the nutral switch then but it was getting late. Maybe next weekend.
I was referring to the P-N signal wire to the PCM, not the start wiring.
I ask because I was wondering if you have a modified Automatic flash and the PCM thinks the car is in park making the IAC compensation of the AC clutch act differently
When an auto is in park or neutral PCM terminal C 15 gets grounded
If you have that grounded ( many do under the dash because they found their trunk release would not work without ) decell fuel cut does not work, IAC follower does not work and I am wondering if the AC vs IAC is different.
Discussion Starter · #14 ·
Ah I see what you are getting at. As far as I know the computer thinks the car is in park all the time. What would be the better way to wire it? Do you know where i can track down some instructions? As far as I recall I just followed the instructions on the swap manual but I may have just taken it the easy way out as I was rushing to get it back together. I know I didn't wire anything to the PCM at that time. It was all under the dash.
http://ww2.justanswer.com/uploads/therock500/2011-02-24_052020_94_camaro_pcm_c_connector.gif
Open up the connector , remove the #15 wire and tape it back.
Now try driving the car.
If you by chance find the car doesn't drop revs the same , that probably means it is working correctly but the IAC follower tables were not adjusted as well as they could have.
Thanks for the info. I will try to get it pulled in the next few days and I will report back. What changes should I expect to see from doing this?
It has been a long time since I studied this and I don't have an LT1 any more.
Pretty sure, if the car thinks it is in park ,
The EGR will not work,
The decel fuel cut will not work,
The IAC follower table will be ignored,
Canister purge might not work
The A/C clutch vs the IAC is a total guess
Sent you a PM
Welcome to the club. Swap aside, I have owned cars that would do this. I think it's somewhat normal for older cars to slightly "jerk" or drop in revs(very minute)when the compressor kicks on. I want to say it's just the compressor dragging things ever so slightly. Just a thought.
Discussion Starter · #19 ·
Sent you a PM
Saturday I got that wire pulled out of the pcm plug. It's didn't make a difference on the behavior on the ac clutch but it did put it in the mode to look for a clutch switch (that is not wired at the moment) so I now know what to pull when I finally do wire up that switch but for now it will have to go back in.
Sorry not getting what your are saying
One clutch switch is to prevent cranking unless the clutch is depressed ( not connected to PCM )
Other clutch switch is in series with brake signal switch to cruise module to disengage the cruise if you push in the clutch ( again not connected to the PCM )
While my LS7 "knows" clutch, I don't believe the 94-97 LT1 F bodies did
If the car runs "goofy" with the park wire disconnected, My bet is the conversion on your programming to "be a manual" might be lacking.
Gerry
1 - 20 of 26 Posts
