is there a way to change the light bulbs in the 96 shifter without
taking out the whole center console ?
thanks!
yes, just take off the shifter plate...
1st, you need to get a flat head screw driver and remove the shift handle pin then wiggle the shift handle off...
2nd, use the same flat head screw driver to pop up the front of the plate.
then just slide it off and your good to go, change blub, twist back in place, put the plate back then shift handle and pin...
done.
thanks lego
i tryed to mess with it yesterday and i took the console lid off and tryed to pop that out but it wasnt working so i figured ask
some one so i dont break any thing!
thanks again LEGO!
