·Has anyone ever experimented with the steering on a b-body? The reason I'm asking is, back when--- I had a 87 Monte Carlo SS and I tried everything to make it steer quicker.(More like a Z28) After a steering box swap and no change, I finally found the difference. The pitman arm on Z28's is/was shorter than that of the Monte. I know all pitman arm splines are the same, I was just wondering if it would have the same effect on the 9c1? (Quicker, more responsive steering???) Has anyone ever experimented??
'95 9c1 white/black 2-ch 3"flows ,3:73w/auburn,headers, cold air,hyperflex
'99 C5 Coupe white/black B&B Tri-flows, cold air, program
'86 Astro w/383 stroker..525 Hp,3000 stall,39.5" Boggers,big lift, should I say more!
[email protected]
[email protected]
