Coolant Pump Driveshaft Assembly
The only thing, i want to mention is. To ensure you scraped all the old gasket off both the waterpump and the block. To help ensure you have a good seal.
You may also want to look into the bleeder valve:
http://www.impalassforum.com/vBulletin/showthread.php?t=229596&highlight=bleeder
This will help when you bleed the system, it will not get the opti wet.
TOOLS REQUIRED:
J 39243 Driven Gear Assembly Remover
J 41546 Driven Gear Assembly Installer
J 39089 Coolant Pump Shaft 0-Ring Protector
REMOVE OR DISCONNECT
Engine front cover assembly.
Rotate crankshaft assembly until timing marks punched on crankshaft sprocket and camshaft sprocket are aligned.
Camshaft sprocket bolts/screws.
Camshaft sprocket and timing chain assembly. NOTICE: Do not turn the crankshaft assembly after the timing chain has been removed to prevent damage to piston assemblies or valves.
Coolant pump bearing retainer bolts/screws and coolant pump driveshaft assembly using J 39243.
Remove and discard 0-ring from coolant pump drive-shaft assembly.
INSTALL OR CONNECT
Coolant pump drive shaft assembly using J 39092.
Coolant pump bearing retainer bolts/screws. TIGHTEN
Coolant pump bearing retainer bolts/screws to 12 Nm (108 lb. in.).
Camshaft sprocket and coolant pump driveshaft gears must mesh, or damage to camshaft retainer could occur.
Make sure that camshaft and crankshaft timing marks align.
TIGHTEN
Camshaft sprocket bolts/screws to 28 Nm (21 lb. ft.).
New 0-ring to coolant pump driveshaft assembly using J 39089.
