Prior to retiring my 91 to the garage I over heated my motor several times on purpose cause I knew I was rebuilding the car should I replace the radiator with my rebuild?
I would say yes, I mean if you are rebuilding the car...whats another couple hundred dollars for a nice new radiator?
No need to replace the radiator unless it has permanent chunks of scale and rust in it, or it has a leak.
If you're going to upgrade to a better radiator than stock, that's the only time you need to worry about replacing a perfectly good stock unit.
