You can use the 95-mid 2000ish GM CD player in your RM, you use your stock mounting bracket from your 93 (with a little trimming), and you will lose the dimming function on your HVAC display. The CD player plugs in the stock harness.
Don't think so! Even to use a 1995-2005 GM AM/FM/Cassette/CD head unit in my 94 RM, I had to use a 1995 (or 96) dash bezel, had to adapt the harness to fit the common BLUE plug in the unit, I had to remove the rear bracket, and use 1995 front brackets.
The dash on a 93 is even far more different from a 95-96 dash than a 94 is.
