T
Have a friend with a 96 Impala SS,he doesn't have the radio code for his car. How can he get it? Thanks
I
try this if it is a cd player.
3169
let me know if it works
T
I don't know if he has a cd player.Thanks,I also did a search in the audio section and found some answers.
[ 04-25-2007, 10:07 AM: Message edited by: THE ROADMASTER ]
O
Originally Posted by kdunville
Try this, it worked for my 1998 Sunfire and a 1975 Monte Carlo.
Press & hold the 2 & 3 buttons @ the same time for about 10 seconds; a 2 or 3 digit code will appear, write this # down,press & hold the am/fm button for about 10 seconds: another code will appear, write this # down, then call 1-800-537-5140 and enter 202108 followed by the # key, then enter the #'s that you wrote down from your radio followed by the * key. The call will give you a 3 or 4 digit override code. Write this code # down so you have it if you ever need it again. Enter this # into your radio following the instructions in your owners manual. If you get an override code that starts with 0, you drop the 0 when entering the code into your radio.
If you don't have an owners manual, try this, press & hold the hour button until the first 2 digits of your code come up, then press & hold the minute button until the last 2 digits show. Then press the am/fm button. This should reset your stereo. It did mine.
Hope you find this helpful.
i found this on another site hope it helps.
T
Thanks guys,I emailed the info-when I hear that it worked for him I'll post.
