I have a 1992 Caprice and it has the standard cassette radio. I want to install a newer theftlock cd player from like a 95 or 96 and was wondering if the wires are the same and will it fit in the dash properly? Thanks
A
Plug in : yes. Although to have the SCV (Speed Compensated Volume) work you'll have to run a wire to the proper pin (Pin 16 on the connector, reference this page) with the Vss signal (which can be pulled from the back of the instrument cluster : reference the 92 Caprice FSM to know for sure which pin it is).
Brackets : might work, might have to improvise with thin sheet metal. Either way, it shouldn't be a big deal
Physical size of radio : it'll fit.
