+2 on thatsounds like the opti vent harness took a crap on you and is letting in moisture to the opti which is causing the secondary ignition to "short out" and not allow current to get to the plugs
so what am i supposed to check to fix that?sounds like the opti vent harness took a crap on you and is letting in moisture to the opti which is causing the secondary ignition to "short out" and not allow current to get to the plugs
