I have a ram-it for the stock swaybar. If I change from the stock swaybar to the F-body one, do I have to change Ram-it boots to the one for aftermarket swaybars? What exactly is the difference in the two ram-it units?
I'm having a problem with my ramit and the hotchkis sway bar. I had Jim at Ramit send me a special filter boot to fit the larger sway bar. I tried to make the new boot fit I even took the fans off, still it wont fit. Man I love the ramit intake and had to go back to the k&n. If your swaybar is thinner then the hotchkis you should not have a problem if you call Jim and tell him your problem. he should fix you up with a new boot. He's a great guy and has great customer service. The only difference from aftermarket boot is the bottom of the boot has a thinner angle. Correct me if I'm wrong anyone.
