Random binding/Ring Gear Came Loose
I'm having an issue where my car will feel like the brakes are stuck on.
I pulled the axles out to examine the bearings and the diff. Everything looks ok including the wear pattern however, the ring gear is loose on the carrier. It can rotate a few degrees fwd and aft. I used locktite and followed the torque spec. Suggestions for a fix cause I'm pretty sure this shouldn't happen?
- Brian
- Brian
