1 - 9 of 9 Posts
Before I panic, anyone have any ideas? Sound's like a ratchet banging around in a coffee can. It will increase when the rpm's go up. Tried searching, can't view any of the old threads.
Thanks,
man - doesnt sound good
Have you drained the oil or checked the filter for metal?
Are you _certain_ it is from the engine, and not the;
1. torque converter/flywheel,
2. passenger side cat?
The cat is my guess. When they come apart inside, they can make quite a racket. Check there.
does it range in sound when RPMs increase or decrease? sure hope it's not a rod cwm8for your sake. also, if that cat was previously clogged i would think there would be driveability problems and possibly a CEL.
DN
Found the problem... somehow, from somewhere (I haven't found where yet) a 13mm x 1 inch bolt got behind the power steering pully and was making the rattle. Problem fixed and a tremendous sigh of relief!
Patience. When whatever isn't bolted to the block now falls off, you may see total destruction.
1 - 9 of 9 Posts
