·I CALLED ARLINTON ABOUT CAPRICE AND IMPALA/POLICE CARS. I TALKED TO THE MAN THAT WAS INCHARGE OF PRODUCTION ON ALL THE CARS,HE TOLD ME ALL FRAMES ARE ALL THE SAME EXEPT FOR THESE DIFFERENT THINGS LOWER BALL JOINTS - THE STUDS ARE ALL 5/8 THE DIFFERENCE IS THE PRESS IN FIT IS LARGER. AND MOTORMOUNTS,FRONT BUSHINGS BETTER THAN STOCK,REAR BUSHINGS STOCK ALSO BETTER FRONT SWAY BAR BUSHINGS AND LINKS. HOPE THIS HELPS almost forgot front brakes are different hd.
