·Hello, I'm putting in the rear end with posi and gear change,3.73.I have read a butt load of info on control arm's,after mkt or stock,and am still not sure which way to go.not worried about centering rear wheel as much as best handling for the $.also I noticed abig differance between the two lower arms, wt# wise and thickness of mat.the thin one had a GM sticker on it,must be just diff between new and old huh? I dont read any posts on the stock arms causing problems,should I stick with stock with all new rubber bushings or urathane? THX
