I have a center bushing cocked in the bracket right now and the LCa is going nowhere :mad: . Anyone have some tips before I make life any harder?
In case if he doesn't get back on here before you leave I believe he is talking about the rear LCA, he has been talking about swapping out rear ends for a bit now.
When you are all done Dwayne, come on down and throw the LCA's in mine!!! Oh, and how about new upper bushings too while you are at it? hehehehe
I have all but one bolt in for the rear control arms. The one not in is the left lower rear control arm where it meets the frame. I managed to get the inner sleeve of the bushing wedged in the bracket cocked a bit and now it will not move either way.
Ok I have just to put the swaybar on, what I did to "fix" the bushing problem was use a bottle jack to ram it all the way up through the bracket. Then a few light taps with a hammer brought it back down into position.
