As I described in another topic, I have replaced the both wheel cylinders rand flushed the brake system on my RWD. It appeared the parking brake did not hold the car on an incline. Finally, had a chance to see what was going on and make adjustments per manual. Depressed the brake lever per the FSM three inches and adjusted the adjustment nut at the equalizer. The manual recommends to tighten the nut until the right wheel rearward with two hands but cannot be turned forward. Interestingly, I could turn the wheel forward but not rearward! So I went ahead and adjusted the nut so I could not turn the wheel at all. Stopped the car on the incline (some 20 degrees), shifted to neutral, depressed the parking brake pedal all the way down, released the regular brake pedal ad the car slowly moved down. There was some braking, but just not enough to hold the car still. What should I do next? It is not a nice feeling knowing you do not have parking brakes. Still better to be aware though. LOL
