Please provide a link that states they are working on a wagon axle kit. The 91-96 wagons were not a high production product and the number still on the road verses those owners who want rear disk brakes seems like a very limited market to design and produce parts for.
Z09B4U - happy to pass along the information. As you will see, they already have a rear kit for our cars. The kit they are working on is a rear kit with function of the parking brake. If you don't want a parking brake you can order from them today. I did send a message to Navy Life last week to see if he is still producing his kits, since the parking brake function appears to work. I have not received a reply.
Below is an email that I received from Kore3
Dan,
Thank you for your interest in our products. The front is pretty straight forward, and either of the kits below could be a good option assuming good fitment with the wheels specified. Wheel fitment templates are available for download
here, and while I’m fairly certain that the 325mm C6 front kit will fit without issue, the 340mm C6 Z51 kits could be a little tight.
GM TALL-SPINDLE, B/D-BODY, ø325mm C5/C6
GM TALL-SPINDLE, B/D-BODY, ø340mm C6 Z51
For the rear, we have matching kits but no parking brake solution at this time for that housing/application. If that’s an issue, let me know and we can discuss options in that regard, as we may have some stuff on the near horizon to address that shortcoming. I would lean towards the 330mm Z51 kit for the rear, regardless of which front kit you choose, as the wheels should clear it without issue and you have a much heavier rear weight bias with the wagon as compared to a sedan.
GM 10-BOLT, 1991-1996 B-BODY WAGON, ø305mm, C5/C6
GM 10-BOLT, 1991-1996 B-BODY WAGON, ø330mm, C6 Z51
For the factory combination valve, you should get the
ProForged stealth bolt kit for that in order to increase the rear brake bias. I’ve attached the front installation instructions so that you can review the spindle modifications required, however please let us know if you have any questions.
I responded with a question and below is the email where they mention they are WORKING towards a rear kit WITH parking brake function.
You’ll get the biggest bang for the buck with the front brake upgrade, but upgrading the rears certainly helps take some of the burden that would otherwise fall on the front brakes. With that said, the parking brake kit we’re working on for the B-body wagon rear uses the Wilwood MC4 mechanical (or electric) spot calipers, so while they’ll function like they should, they probably won’t offer the same holding torque as the large drum brakes from the factory. Our goal is to have these kits available for sale in the next 3-4 months give or take, though nothing really seems to be going per schedule during the pandemic.
