75w 90 and 2 bottles of the GM additive.
Don’t use any synthetics.
I haven't commented on this subject, but feel I must since it's been repeated so often.The "no synthetic with an LSD" is a given. Wasn't the latest skinny though to use 2 bottles of additive ?
There do seem to be plenty of people that had problems with synthetic. In my searching most people were trying M1 oil. I did find a few people that had tried Amsoil with no complaints. Because I tow a travel trailer and didn't want to constantly be changing my rear diff. oil I tried the Amsoil. It has been in there for a year or two now. I used the Severe Gear 75W-110 diff. oil and 1 tube of the Amsoil Slip Lock additive. On rare occasions I can hear my limited slip making some slight noise in a tight turn but typically it is quiet. I'm very happy with it. It made a little noise (slight groan, barely audible) a few times about 2 weeks after I changed it and I heard it again this weekend when turning into my garage after I had just given the limited slip a work out backing my travel trailer into it's parking spot where the car is going backward up hill while turning on grass. It was at least a year there with no noises at all. My 2 cents. I used Valvoline non-synthetic 80W-90 before with 1 bottle of Kendall additive with no issues previously.I haven't commented on this subject, but feel I must since it's been repeated so often.
The statement is false about synthetic. What are the facts? Has anyone documented failure/slippage with synthetic?
I have run the Eaton carrier and 3.73 gears from Dan for the last 6.5 years, with 95,000 miles running Amsoil gear oil and 1 bottle of additive at each change.
The hot-rodding retired Marine who did the gear swap for me suggested I go to Amsoil after 500 break-in miles with traditional dyno juice 80/90.
I did just that, and have swapped out the fluid 3 times (Once for new rear cover install, second for new moser axles & BRGS installed, and third to swap after I totaled my 9C1 and I swapped the rear into my current Civilian ride). I have done approximately 75% of the mileage doing city driving, and the rest during long trips to and from Austin to State College.
I have found nothing to substantiate the argument of not using synthetic from my first hand experience.
