Hello Everyone. I have pretty much totally rebuilt my rear axle assembly. I installed Moser axles (brand new from Moser Website) into a Trutrac by Eaton Differential (axles are clipped and locked in).
*I have after market drilled and slotted rotors that came with the car. I had them turned at Napa Autoparts. One rotors measured thickness is on the maximum thickness size as per factory service manual Maximum and Minimum tolerance. The other sides rotor is about .020 smaller if I remember. However this happened is beyond me. The rotors differed before I had taken them to be turned so I’m not sure if the rotors we’re equal thickness new or if they somehow wore differently. Napa didn’t bother to take the one down to match the other. Anyway, with all this information stated, I need to know this:
Question: What feeler guage thickness in thousandths of an inch is a good safe clearance gap I should have between the 2 brake pads and rotor?
Notes: 1. My Caliper pistons (All rebuilt) are pushed in the caliper totally to their maximum-meaning brakes “not” pressed if you will. 2 I tightened 3 lug nuts onto the face of the rotor to square the rotor against the face of the axle. 3 My brand new Autozone (lifetime) pads may be slightly thicker than other brands-as I had to belt sand some material off each pad-about .010 each to get one caliper to fit over the Napa finished rotor that was on the high end of the FSM thickness tolerance.
My point of question here again: How much feeler space should be between the pads and rotor? I have them to where they are not tight but they “do” rub slightly on the rotor naturally as the pads are just held in there by that cheap spring on the pads and that H clip slider thing. What I’m saying is I can force the pad away from the rotor but when I release the pad falls back on the rotor. (Axles are locked in, brake brackets tight, rotors tightened against axle faces, caliper pistons opened all the way)
Any input here Is much appreciated. I’d hate to warp my newly turned rotors. I’ll be searching the book for any information. .....Thanks
