1 - 20 of 23 Posts
Anyone know what qa1 coil overs fit the rear ended if a 95. Also is it a direct bolt on or requires modifications?
The rear suspension of these cars is a coil AND shock absorber system with separate mounting points.
A coil over is a strut system with the coil and shock absorber forming one component using the same mounting point.
You would have to fabricate a new mount that can handle all the weight and stresses on each rear wheel.
I am not sure why you want to re-engineer the rear suspension but I urge you to read the suspension stickies and then come back with some information as to what you want your suspension to do. Some people want a soft ride some race. Mine is to give good handling and prevent damage the bad roads can cause.
I understand that but I’ve came across some pictures where advertise the qa1 coilovers. So I was asking for opinions. A shop out of Texas claims there’s no modifications needed and says I can buy the parts directly from them. But then I realized there is a few different coilovers the company makes for my car.
Contact Josh at Three Pedals. He can advise you on the best route for your Impala. He is a vendor for QA1.
Michael
I do not understand how these are desirable
You dial in your ride height and then are stuck with the spring rate at that point even if it is to soft or too hard. Do I have this right?
Spring rate is a minor variable in ride quality (along with tires/pressures) - damper settings are the major variable.
You might want to consider their terms and conditions.
https://www.qa1.net/terms-conditions
THE BUYER UNDERSTANDS AND EXPRESSLY RECOGNIZES that racing parts, specialized street rod equipment, rod end bearings, and ALL parts and services sold by QA1 are exposed to many and varied conditions due to the manner in which they are installed and used. BUYER ACKNOWLEDGES that QA1 does not have full knowledge of the intended use of the goods, and BUYER WILL DEFEND AND INDEMIFY QA1 upon demand against all claims, actions, liability, loss and expense (including investigating expense and attorney fees incurred in litigation or because of threatened litigation) for any loss, damage or injury, either to a person or to property, resulting from the direct or indirect use of any QA1 products or inability by the buyer to determine proper use or application of QA1 products. With the exception of the limited liability warranty set forth above, QA1 SHALL NOT BE LIABLE FOR ANY CLAIMS, DEMANDS, INJURIES, DAMAGES, ACTIONS, OR CAUSES OF ACTION WHATSOEVER TO BUYER ARISING OUT OF OR CONNECTED WITH THE USE OF ANY QA1 PRODUCTS. MOTORSPORTS ARE DANGEROUS; AS SUCH, NO WARRANTY OR REPRESENTATION IS MADE AS TO THE PRODUCT'S ABILITY TO PROTECT THE USER FROM INJURY OR DEATH. THE USER ASSUMES THAT RISK.
Could not find one place on the site that said any part is "street legal " or for "road use" Just talk about "street rods" parts. As usual "buyer be ware" Some companies do not stand behind their products, some expect you to protect them if they have legal issues.
I've found that to be pretty typical for anything safety related such as suspension components, brake upgrades, dampers, etc. In my opinion it's a similar situation when buying F.L.A.P.S. C.R.A.P. When it fails they'll gladly replace it but if your "globally sourced" tie rod breaks and you careen into oncoming traffic causing an accident, I don't expect much/any support from them either in terms of liability either. I'll take my chances with a domestic part from a small company than a global sourced part from who knows where which is primarily run by accountants. Just my thoughts/opinion on the matter...
Fix Until Broke
I will leave this to the experts but will give you two practical examples:
NASCAR makes "spring adjustments", they use wedges in the springs, and make track bar adjustments during a race. There is no mention of dialing in the shocks during a race.
I was researching a car a couple of days ago and found the shock adsorber was common to several very different cars. IE four door car and several different two door sports cars. The springs for each car was very different.
No, not exactly.
A linear spring coil over has the same spring rate no matter the height adjustment.
If you have a 300 lb spring,
It will move 1 inch for every 300 lbs load no matter where you have the collars , and height, cranked up or down.
Rate adjust, you change the spring.
I do agree, any bolt in kit will be lacking in areas.
What I do not like is the poly end bushings , which in this application are being asked to carry the entire weight of the car.
Z09B4U
May be I did not express myself well, Other forums have complained that the QA1 "recommended" spring rates are not to the taste of the buyers. Then in some cases there are not any other choices they would like.
The kit the OP linked to has 250 (medium) springs. IF this means 250Lb/in this is on the stiff end of the scale for b bodys. I could not find the soft or hard springs. My point was that QA1 may not have a good spring choice for our cars.
Ah, misunderstood what you were saying-asking.
While my B body does not have coil overs , every car here in the shop does. Bins and bins of springs for some of the cars in 10 lb increments.
Now, if I was just smart enough to pick the right ones :)
Are QA1s the hot ticket, right choice for an Impala ? No clue
Found the spring choices 200. 250. 300.
In their pdf they explain spring rate but do not use the units in their charts.
in the chart below the range is 18 27 37(wagon) which is 105, 155, 210Lb/inch
Moog suggests 173Lb/inch
Fix Until Broke
Some clarifications. They do not use 'wedges'. They put wedge into the car. Meaning they dial a coilover up or down to put more force on a particular corner to compensate if the car is loose or pushing. This is a before and during race adjustment. They did however also dial in the shocks too, just not during a race as the track itself hasn't changed (bumps/dips, etc.) And it's more for the stiffness of the spring used that isn't being swapped out during a race.
Shock absorber, if referring to the QA1 shock, very true. But it's adjustable. If you look our the replacement shocks for caprice, other than the 1516/1517 bilstein, they also are just as common on many different cars.
If the car is something more than a daily driver, the coilovers certainly have their place.
Moog doesn't suggest a 173 lbs/in spring. They have a 173 lbs/in spring with a free length that when installed in a caprice provides close enough ride height and stiffness. They also offer a 133 lbs/in spring for the softer FE1 suspension cars. Both springs fit many applications just like shocks. A very abbreviated list: I myself am running the 199lbs/in rear springs with a stock rear sway bar. Prior it was the stock SS spring with a 1 1/2" sway bar. Handling's been about equal. The stiffer springs ride firmer, but handling is also crisper.
1 - 20 of 23 Posts
