hey guys i know this topic has been covered, but didnt see anything about if there is any kind of spray that would get rid of this. and can anyone really pin point what the squeak is. i can recreate the noise when i rock the rear end.
I have the same problem and it is the exhaust rubbing on the rear upper control arm, makes a nasty squeaking noise. Do you have any aftermarket suspension or exhaust on the car? Could be polyurethane bushings in the control arms that need greased.
well i think my bushings are original. what to use to grease or should i just replace them?
i dont think it is my exhaust
check the upper control arms and make sure the mounting holes for the contol arm aren't all reemed out and distorted.
