Hello Everyone. I am going to be installing a Hotchkis spring set. My axle is painted with Por 15 And the frame is painted with por 15 as well. I have two red energy suspension spring insulators that came with my trailing arm bushing kit (purchased separate). Do these go on the axle end or on the frame end of the spring? My manual says “wagon only” for insulators on the lower part of the spring at the axle perch. I’m not sure if this means the 94-96 Impala didn’t come with insulators on the bottom????
1. Did the Impala only have insulators on the top?
2. How should I get them to hold? Gorilla glue and some kind of clamp over night? Would Gorilla glue be too stiff? Is there something else anyone has that is a better suggestion? They just slip off. I’d hate to lose them on the road
3. I have the 2 red energy suspension Insulators and 4 black ones that camewith the Hotchkis set. What’s the best thing to do here Red or black or both? Is there a reason the bottom is not called for in the Factory manual? ........Thanks
